Clears the packet and byte counters for one or all static LSPs.
lsp_name | Identifies the LSP for which counters are to be cleared. |
all | Specifies that counters are to be cleared for all static LSPs on this LSR. |
N/A.
None.
The following command clears the counters for a static LSP:
clear counters mpls static lsp lsp598
This command is available only on the platforms that support this feature as described in the Switch Engine v33.1.1 Licensing Guide document.
